02 yukon xl, no start
ugh
So i have an 02 yukon xl, 5.3 129,000 miles on it. One day i get up for work at 5 am and drive my truck 20 minutes on the parkway no problem. At 2:30, i drive 15 minutes from one job site to another, again no problem however it was drizzling. At 10:30 i leave the job site to go home and the yukon won't start. Cranked normally but just wouldn't turn over so i left the truck there. The next morning we return and the truck starts fine and has started every time since.
Truck had over half a tank, new battery. Also has had engine light for an evaporative emission system leak. Any ideas why it wouldn't start one night
Ok - you're contradicting yourself here .....
You're saying it cranks over (turns over) but won't start ... or you're saying it won't turn over (crank)?
I'm guessing it cranked, but wouldn't start. On that note, you'll need to see if it was a spark or fuel failure. My guess is spark, because you mentioned drizzly weather ... but I'm guessing over the net without seeing the thing, so I could be way off base.
An old school timing light is one of the easiest spark testers to use, so long as you know the light is good. Can hook it to a lawn mower just to make sure the inductive pickup still works, then throw it on the truck when it dies to see if it flashes when you crank.
I would pick a day where you have plenty of time, and another vehicle to get somewhere if needed - then, mist down the engine one small section at a time, concentrating on the ignition system first. Water is excellent at finding ignition faults & bad connections (and vacuum leaks too). Keep spraying small sections at a time as it idles. Give it a couple snaps of the throttle and see if it bogs out or stumbles. If that doesn't do anything, just keep working your way outward from the engine with the mist. Could be a chaffed wire somewhere that just needs a little water to short to ground.
Hello,
We apologize for the unexpected concern with your Yukon. If you would like for us to look into this further, and reach out to your dealership, let us know in a private message! Be sure to include your VIN, contact information and preferred dealership.
Thank you,
Bret B.
GM Customer Care
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
