2014 GMC Sierra DRL and Side Marker Lens Smoke Tint
eppyfish
Need some advice from you folks on here with more experience in headlight mods than myself. So I have a 2014 GMC Sierra SLT with the factory projector housings. I recently installed the TRS Morimoto Sierra Elite system with 35w ballasts and 5500k HID bulbs. I’ve been very happy with the system and I don’t have a desire to swap out my projectors for the FXR or anything else at this time. I am however looking to black out the headlights and improve the look of the housings. I have some experience with baking and blacking our housings on past vehicles, so this is not totally foreign to me.
Factory housing and lenses look like this
I want to...
-Paint most of the chrome in the housing black
-Remove the amber reflector and replace with smoked reflector
http://klearz.com/sierra_headlight_markers
-Tint clear upper and lower DRL lenses to a smoke color like these
http://klearz.com/sierra_drl
​This is what the whole marker/lens set looks like for one headlight
The clear corner reflector and turn signal marker is $90 per set from Klearz.com and I can't find a clear corner reflector anywhere else. If I bought the smoke drl markers from Klearz too ($160) then I’d be looking at $250 in reflectors/lenses alone. Might as well buy a set of aftermarket lights for that price. I like the OEM housings and DRLs though, so that’s why I’d like to figure out how to tint the upper and lower drl lenses and only have to buy the smoked corner lenses.
After reading a lot of reviews on VHT, I don’t think that’s a good idea. Whatever I do, it’ll be sealed in the housings, so touchup any issues would be a PITA. I have done some laminx and tint film in the past, and that’s where I think I’m headed. You think I can expect the tint/film to stay in place. A quality product like a 3M film, with proper heat to set it, shouldn’t deform inside the housing should it?
Bring on the suggestions.
End game will look something like this, but I don't want paint over the drl lenses, just a smoke to tint them.
check out www.lamin-x.com - I used there light tint on my fog lights.
I used Laminx on my Silverado and loved how it turned out 9a32bfb96fa61c1423ce289be756854c.jpg
good looking truck. ANY light loss (headlights) , Do you have Hid's or led's ?
With halogen lights, I lost quite a bit of light. I just put some hids in and it's a loooot better.
Trainer, are your whole headlight housings covered in Laminx? Your corners look very clear. What about your fogs? Great looking truck BTW.
I have clear reflectors with white/yellow switchback turn signals. They cover all four lenses. If you order a set, they send you ones for your fogs. Obviously I'm not running the stock bumper so I cut those down to fit.
any reason to think that a quality tint film on the back side (smooth side) of the LED lens covers would start to bubble or peal while the LED lights are on behind them? I don't expect there's enough heat to cause deformation if the film is installed properly.
thanks again guys.
what HID's kit did you use ??
35 watt, 5500k light, gun smoke laminx tint. Pretty sure that's the darkest they offer
Thank You
Thank You
You bet, bud. I want to see pictures of how yours runs out if you go that route too! If you have any more questions, shoot me a message
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,494 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
