Fuel pressure
Swimmer8366
So drive the truck this morning doesn't miss fire till I get to my destination hook scanner up have 1004 miss fire history on cylinder 2 and 1200+ on cylinder 7 if I remember right that's firing order 2,7 thinking you may be right Jsdirt injector???
Sent from my Z981 using Tapatalk
If you have 48 at key on engine off, that's way low. These engines can misfire a couple of pounds low
Suggest new filter new pump?
I'd double check the acceptable fuel pressure readings, make sure they are 55-62
Ordering injectors any one know which ones 22lb or 28lb injectors?
Ordered the 28lb injectors today along with pump. Gonna put filter pump and injectors in it. I don't like the low pressure
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,268 Guests (See full list)
