Undercover Ridgelander
bearcat77
Anybody have this cover yet? Looks like a cool concept, but I'm wondering how well they made it. Supposed to be available for the HD trucks around the end of March, and I'm hoping it's worth waiting for.
It looks very similar to the "Solid Fold" tri fold hard cover by Extang. The Solid Fold seems fairly cheap, but definitely functional and something I considered when shopping for an easily removable cover for my bed. This seems almost identical, just whole body cover on hinges instead of a folding cover.
https://www.extang.com/p-36824-solid-fold-2-0.html
  • 8 months later...
Bearcat, did you ever get a Ridgelander cover? I am thinking of getting one for a new 2500HD. I can't find much feedback from actual owners of this cover. I've never even actually seen one in person.
  • 8 months later...
I didn’t get one. I needed a cover right away. I ended up making my own version of that using a Retrax MX Pro and a Thule roof rack mounted on top of the Retrax.
Search for the thread “Alternate bike rack while towing TT”
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
