Belltech lowering shackles, 2"
Belltech rear lowering shackles for 99-03 Silverado or Sierra, #6400, 2" max drop, excellent condition :fume: . Used on 4x4 to level out front/rear rake. Will work on 4x2 also and maybe older models please check application guide. $40 plus shipping from area code 87114, New Mexico. No handling, just actual cost depending on how fast or slow you want them. Thanks for the consideration. :jester:
  • 1 month later...
