16 Sierra Text message App
On the 16 sierra, SLE... I Noticed when trying to disable the text notification setting in the head unit that more often that not if you click on disable text notifications it doesn't actually do anything. The setting doesn't change off of ON.
If i then shut the car off wait 5 + minutes turn it back on either it is then set to OFF or still is ON.
I have also noticed that it will randomly turn it back to ON even when its disabled by itself...
Anyone else seeing this?
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
