Stand alone A/C
Can someone advise me on how to wire a stock a/c system to run with an aftermarket EFI and no Stock computer.
I've got a HT383E with a proflo xt intake and I want use the full blown efi kit from edlebrock instead of the stock computer and my harness that I adapted to work with this combo.
I want to use edlebrock harness with an aftermarket trans controller, The only issue is getting the a/c to work. Please advise if you have any ideas.
Thanks
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
