1999 Chevy still over heating
Ok I have a 1999 Chevy z71
With a 5.3. I had a coolant leak from my water pump so I replaced the pump and thermostat. Flushed the radiator twice. I have burped the system 2-3 times now but sometimes the truck still gets over 210 and up around the 230 range. Now I have an hour drive to work and somedays I drive to and from work with no problems and somedays I don't make it 20 minutes before I see the temp jump up. It was boiling over out of the reservoir tank but after the second thermostat I replaced it doesn't boil over anymore it just gets up close to 230 Any help would be appreciated.
If it keeps getting air pockets that require burping the cooling system, it may be a head gasket issue. You could have a clogged radiator or restricted air flow across the condenser and radiator.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
