Backspacing/size rims for 33" with a leveling kit
bowdy
Hey y'all,
New to the forum, had a question about rim/tire set up on a 2017 Silverado Crew Cab Short Bed with a leveling kit- I want to run 18" or 19" rims with 33" toyo open country tires- does anyone run a set up similar to this? Any rubbing? Also what backspacing should I get with this setup?
Thanks for the help!
I have 33 12.50 r20
20 inch rims, x9 20 mm offset
2 1/4 leveling kit
No rubbing and very close to the body the way I wanted it.
http://www.gm-trucks.com/forums/topic/196044-what-is-the-biggestwidest-tire-without-lift-on-16-1500-z71/?p=1918071
read post #21. click on results.
once you buy your new tires & wheels, fill out the form to add your info.
Anyone else reading this who has aftermarket tires, please add your info to the form as well. The more info that is added, the more useful this document will be. Thanks!
Glad to see we are still linking to that. Makes me feel like all that work didn't go to waste.
I'm doing my best to send people there. If we can populate it with 100 or so entries, I think it will be quite beneficial.
once you have the data recorded, it can be used forever.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 628 Guests (See full list)
