Multiple Control Module Codes
Randomly this week without warning my check engine light came on. Like usual, I figured it was another notorious Fuel Evap. code. I tried to reset the power but the check engine light stayed on so i went and had the codes read. A total of 14 codes came up (See below). Any recomendations on my next step? What to check, what to replace?
And by the way, the truck has no noticeable changes since the codes showed up. everything is running as normal.
Codes:
U0073- Control Module Comm Bus Off
P069E / P064A- Fuel Pump Control Module
P0193- Fuel Rail Pressure Sensor Circuit High
P0232- Fuel Pump Module Control Circuit high
P025A- Fuel Pump Module Control Circuit Open
P0601- ICM Memory Check Sum Malf.
P0602- PCM Program Malf.
P0603- ICM Keep Alive Memory Malf.
P0604- ICM Random Access Memory Malf.
P062F- ICM Malf.
P06A6- Sensor Reference Volt A Circuit Range
P2635- Fuel Pump A Low Flow
U0100- Lost comm w/ ECM / PCM
Any help or suggestions are appreciated.
Thanks in advance.
Mike
You got some serious issues with... something.
I would start by unplugging the battery and let it sit over night with the headlights on.
That will 100% completely reset the computer.
After that:
1) Disconnect the ECM, to check for a bad connection.
2) Check for any loose or poorly grounded wiring harness or engine ground cables.
3) Take her to a dealer that agrees to just do a diagnostic, so that YOU can replace the parts that are bad. Make sure they know its not a free for all , here is my credit card type of thing.
    Selfman
    Selfman
  • Who's Online   3 Members, 0 Anonymous, 386 Guests (See full list)
