Wiring a light off of hazard switch
I'm a paid on call firefighter and have a flashing red/white light in my truck. I'm tired of having the cord hang down and having to plug it into the cigarette lighter. I was hoping to tie in the light to the output of the hazard switch (I'm presuming this would go to the flasher module). I run with the hazard lights on as well to a call. Anyone done this or does anyone have a wiring diagram I could follow.
I have a 2011 Silverado 1500 Z71 5.3L.
Thanks.
Just read this post and want to clarify that I want to tie into the hazard output wire BEFORE the flasher module as the red/white light flashes on it's own.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
