I want a bed liner
Bill89
Somebody here has to know where I can get a bed liner that doesn't cost and arm and a leg.  I called Chevy and my cost is $250.  I just don't want to spend that much.  So help me out guys.
check local places.  A local parts place by me always has em on sale for like $149.99
Ryan is right.  A drop in plastic liner shouldn't cost more than $100-$150 dollars.
Personally I would get an "under-the-rail" liner, but that is just my opinion.
If I didn't have a step side I would get this one.  But my truck is black so it shouldn't look to bad.  Besides, anything would look better than 13 years on carrying things in the bed.
I know you don't want to spend the $$$, but I bet for your truck you could get a "spray-in" for about $300.  I think they are the way to go (Unless you get a bedrug like mine).  I know Arma Coatings runs specials here for $350 for a fleetside shortbed.  I'm just guessing you could talk them down on a Stepside...
Go "Herculiner"!
See my post in "Product Reviews" forum.
Get anything BUT a dropin bedliner.  Those things are just way to slick and send things in the bed shooting around like they came out of a gun.  I don't want to have to tie down everything I put in the bed.
i second Friz herculiner is the way to go, $100 just a spary in liner you do yourself. can get it at most auto stores
I'll add to the madness, get a spray in, or spend a day and do it yourself.  You won't regret it.
Over the rail drop in's tend to warp under the heat of sun.  I should know, looking at our old work trucks (long bed chevy trucks) even w/ 3 of those stake pocket tie downs holding them in they still warped in between them after a few years.  And this is WI where the sun doesn't shine for about 8 months.
Drop in's are a PIA.  I use the tie down loops often and the liner partially covers them. I hear that filling fuel tanks in a sprayed bed is not a danger as in a drop in but I don't know if this is a trueism. My next one will definitely be a spray on or a DIY brush on.
I had my local Line-X dealer do my son's S-10 and it looks great.  They cover the top of the tailgate and can do over the rail.  The only complaint about the Line-X after a couple of months is that I was hoping for a bit more friction to keep loads from shifting.  I think there are other spray in liners that are rougher.  If I had an '89, a low budget, time, and full mobility, I'd probably go with Herculiner.
Ok, I will go with the spray in type.  I called the local parts store and they have a kind that I roll on for 50 bucks.  I know I need to do something. All the scratches are driving me crazy.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
