Worth upgrading radio unit ?
Right now I have stock radio unit and I believe it's a io3 no nav , no Bluetooth. just radio/ aux. What would I need to upgrade? I've seen some people get the i06 upgrade and Install it . But do I need to get a stock unit with a 8 "screen or could I go aftermarket like a Kenwood. Do I even need a io6 module ? Looking for ideas . I know it isn't cheap but am pretty interested.
Apreticate any feedback!
Sent from my SAMSUNG-SM-G935A using Tapatalk
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
