Help with codes (AC related)
zmnypit
Truck: 2014 Sierra All terrain.
Been having trouble with my AC for a couple weeks now. Works, dont work, works dont work and so on. I took it today and had a evac/vac then recharge done so I know its within spec. Once recharged the temp on low using a thermometer would never get below 60* so the mechanic ran a scan and found the following under HVAC controls:
B1325 Control Module Power Circuit
B0413 Main temperature control feedback circuit
U1509 LIN Bus 9
U0020 Low speed CAN Bus
Any of these cause an hot AC on certain days? If so what do I look for?
Thanks!
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
