3 hours ago, njk4o5 said:
i have 35x12.5's on a ebay level block, norcal fender mod, and i think a 1.5" body lift
So you're sitting at about 3-3.5" of lift? Do your tires come near to rubbing that front, rear, outer corner at all when flexing? Also what's the offset of your wheels?
it only lifted the truck like 2.25"
they will rub the liners around full lock on a off level surface. ive never done anything about that as it barely ever rubs but i could probly tie the liners back a little and it would go away
I'm getting 35x12.5R17 BFG KO2's installed next week, I've already done the Zone NorCal Mod so I'm committed to making them fit properly LoL. I'll probably need to do a bit more cutting on the plastic corner molding but I'll know once they're installed.
  • 3 months later...
Hi everyone! I would like to ask if anyone run on 35 on a 22’s stock rim 2.5 leveling kit?
Edited by SLTblackMamba
  • 2 years later...
On 1/4/2018 at 9:57 AM, THE_Engineer said:
I am running 35x11.5 Nitto ridge grapplers on 2.5" RC leveling kit. I trimmed the wheel liner and it doesn't scrub anymore except on full lock it does hit the sway bar.
IMG 4157
Dude the haters can hate but I'm running practically the same thing and it looks great. I have a 2.5 inch motofab leveling kit on the front only and I jammed some 35 x 12.5 x 20 Nitto Terra Grapplers on there and the only time they rub (which is minimal) is when I back up turning left on full lock. It looks very similar to yours. I did some minor cutting but rubbing like I said only happens when I am backing out of a parking space or something. So if anyone is wondering, 35s WILL fit with a 2.5 level with only a little cutting and some minor rubbing. If you can deal with that then by all means DO IT!
    btm
    btm
  • Who's Online   4 Members, 1 Anonymous, 1,517 Guests (See full list)
