Evap canister replacement on a '17?
Long story short the evap canister was broken when it was setup on the hoist, I guess the bracket isn't strong enough to support the weight of the truck? I didn't do it they did, brand new truck. The dealer is sending me a new canister and bracket since it will be faster for me than the 3 hr round trip back to the dealer. I crawled underneath and looked at the job, looked simple one bolt and two lines. Is there a trick to removing the two lines? It looked like just push out the retainer and remove the line from the fitting? Is it really that simple or is a tricky one. Thanks!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
