99 2WD Silverado w/o tow package
Friend of mine just installed a hitch and reciever for his truck, but is running into problems wiring the lights for the trailer. I told him to look for a plug and play setup, so he wouldn't have to splice into any wires. He said, they don't have a plug and play for his truck, only the splice kind. Is this correct and if so, anyone got a link or instructions on how to wire his truck for his trailer lights? I tried the search feature, but got 22 pages of trailer brake wiring. Thanks, Chris
There should be a set of wires attached to the underside of the bed just above the spare tire I believe, that what I've heard that GM already put in the wires for it. Hope this helps. :cheers:
You can also get a pre-wired connector for many of the brake controllers which will allow you to install the controller without hacking the under dash wiring harness.
I installed a Tekonsha Prodigy that I bought online for less than the local trailer guy wanted to sell me a basic tekonsha controller... I picked up the prewired connector (http://www.tekonsha.com/bch3025.html ) and I was wired up in less than 5 minutes. Mounting the controller added another 10mins.
I'd recommend this setup in a second. Works great and total cost of $130.
later,
bobc
Does the factory plug on one of those plug into the realy center on the back of the bed? If it does couldn't he get one of those?
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 652 Guests (See full list)
