2016 silverado p0300 random misfire and O2 sensors
I drive a 2016 silverado that i just recently brought as a salvage title for a good deal  not under warranty ... recently as i was driving the truck felt a lack of power and it was late shifting like it didnt know what gear to go into next then the stabilitrac light along with a CEL the truck started misfiring When i took it to get the codes checked i did have multiple misfire code P0300 along with emission codes P0030 P0031 P0050 P0051 P0135 P0155 P0157 anybody have this issues? The truck was running perfect before
You need to check for vacuum leaks first, then fuel pressure. If vehicle is running lean it can cause problems with cats and o2 sensors
Sent from my SM-G935V using Tapatalk
Those are all heated oxy sensor codes. Issue with the heater portion not oxygen sensing. Look for a power or ground issue .Power from underhood fuse box. Ecm grounds as required.
    CaptainDad
    CaptainDad
  • Who's Online   0 Members, 0 Anonymous, 416 Guests (See full list)
