Replace rear shocks with coilover
Nasty
Has anyone done this? I have rear shocks relocation but my truck is very soft in the rear.
If anyone has done it what spring rate was used.
To swap out your rear shocks with coil overs you would also need to revamp the entire rear suspension, removing your leaf springs to install a custom 3-link or 4 link set-up.  Common for offroad racing...not a easy or inexpensive task.
You would need to weigh your rear end and consult with a custom builder like KING to get set up with a coil over.
I don't need to link it.  I had the same setup on my v8 s10 years ago.  I want red rear double adjutable shocks but my rear is way to soft so I want the spring rate to stiffen it up a little       I kknow guys that ate linking the rears on regular cabs are using a 180lb spring. But the entire weight of the rear is on them.   So I'm thinking 100-120 lb spring would be ok.  I know there's 1 guy here that did it but I'm not sure who it is
You talking about running a mono leaf on coil overs?
Sent from my SM-G950U1 using Tapatalk
Not a mono leaf. Stock leaf pack.   And I use Viking    I have Vikings up front.   I know the length coilover I need in the rear. I just really need a spring rate     maybe I'll have it weighed
    B Cork
    B Cork
  • Who's Online   4 Members, 0 Anonymous, 652 Guests (See full list)
