No horn blows when hit lock button
I have a 04 Sierra z71. I just got a new keyfob and programmed it and now when I hit the lock button the horn doesn’t blow. My buttons on my steering wheel do not work. Is there a way for me to get into my settings to change the setting on the horn without the steering wheel buttons??
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
