Stop Leak Liquids (Gasket Fillers) Any Good or More Trouble?!?
So I have a minor leak, I have to add coolant every month or so. And usually around 3500 Miles after an oil change I have to add a Quart of oil; tried 10W40 this time to see if that helps with the oil leaking. But the bottom of the engine is usually covered in oil, and when I had to get my parking cable replaced the transmission shop said I had I believe a rear main seal leak...
So my question is is it even worth trying to use Liquid Stop Leaks or should I just actually replace the gasket? I definitely know replacing it is the preferred option, but I think it might be pretty hard for me to do myself? If not please say so! And I definitely don't have the money to get done at a shop. Thanks everyone for your help on this!
6 hours ago, muddkatt said:
IMHO the "stop leaks" are just snake oil.
Yeah that’s kind of my thinking on it. What do you think the problem could be? One guy said it could just be the oil pan bolts are loose... the transmission pan bolts were loose, but thought that was the oil pan so I didn’t mess with the Actual oil pan I’ll do that tomorrow...
what do do you think the coolant leak could be? That same guy said it could be the water pump...
Check the pan bolts, then clean the engine. Brake cleaner will dissolve the oil quickly. Then monitor it closely to determine where the leak(s) are coming from. Note, thicker oil will not stop the leak so use the recommended oil.
The water pumps are known to seep at the hole on the bottom, and sometimes where the gasket to the engine block is.
BTW, what year and engine are we talking about?
Oh yeah sorry about that 2000 1500 Silverado 5.3 Z71
awesone thanks I didn’t think about brake cleaner...
and yeah I think I’m going to go ahead and change my oil again, I did a seafoam intake cleanse right After I changed my oil last 3k miles ago, a guy on another forum said to just go ahead and change it... andbso I’ll put the 5W40 in it this time again. Synthetic? Or does it really matter?
You should be running 5W-30 in the 5.3. I use Mobil 1 and run an "extended" oil change schedule. If you change every 3-5 thousand miles, then a good conventional oil will be fine.
Go to NAPA and get an oil UV dye and add to your next oil change and after you clean the ending.  Get a cheap UV light and start checking it regularly. You should be able to source the leak.
i have had some luck with the better seal additives but on older motors.  Theory is that they will swell the seals.  Still doesn’t treat the root cause.  Find your leak and fix it, new gaskets or seals.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
