PASSENGER DOOR LOCK ACTUATOR
1999 Silverador 2500 LS with power door locks.  Passenger side door lock actuator will "lock" from key fob, driver's side button, passenger side button.  Will not "unlock" with any of these three controls.  Driver's side actuator locks and unlocks from all three controls.  I would like to know the terminals or wire colors in both the driver's side and passenger side buttons so I can jumper....without taking all of the door trim apart to get to the actual actuator.  I am trying to trouble shoot whether the actuator is bad or just a broken wire somewhere.  Thanks for any help.
sorry for incomplete info. but this is what i can find.
1999 Chevrolet Silverado Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Red  Ignition Switch Harness
Starter Yellow  Ignition Switch Harness
Ignition Pink  Ignition Switch Harness
Ignition 2 White  Ignition Switch Harness
Ignition 3 Brown  Ignition Switch Harness
Accessory Orange  Ignition Switch Harness (Heat/AC)
Tach White V6  Coil, If V8 at Any Coil, 1 Cylinder Setting
Brake Switch White  Brake Switch
Trunk Pin n/a
Parking Lights Light Blue (+)  Light Switch
Head Lamp Yellow (+)  Light Switch
Factory Disarm Light Green (-)  Keyless Module
Door Trigger Tan DR. (-)  Light Blue Passenger's Module below Steering Column
Door Lock Light Blue (+)  Keyless Entry Module below Steering Column
Door Unlock White (+)  Positive Trigger
Driver's Lock Gray  Driver's Kick Panel
Driver's Unlock Tan  Driver's Kick Panel
Passenger Unlock White  Driver's Kick Panel
Horn Wire Black (-)  Steering Column
Windows Up LF=Dark Blue, RF=Light Blue
Windows Down LF=Brown, RF=Tan
but those wires would be running together outta the door boot or kick panel where ever you want to test them. the door trim is pretty easy to come off, but i have done it plenty of times
  • 3 weeks later...
MUCH LATER.....I finally determined that the latch mechanism was bad.  After I replaced it, the UNLOCK would still not work.  I traced wires, checked fuses, traded the LOCK and UNLOCK relay positions in the fuse block with no change.  I then discovered the "third relay" and exchanged it with the first.  Everything now works properly!!!  Who knows why?  Could be a dirty connection in the UNLOCK relay socket?
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
