help please 4l80e 4x4
hey I really need some help
I have a 2002 sierra 2500hd 4x4 and my revers is slipping my transmission on the side is marked hydromatic and under says 4l80-E
ive been looking around and seen this one but on the side its not marked can anyone help me,  ive been looking at pictures and some seem marked and some don't is there any difference,
heres the link I was looking at
https://www.kijiji.ca/v-transmission-drive-train/oakville-halton-region/4l80e-transmission/1350592578?enableSearchNavigationFlag=true
