My 5.3L engine lifters and camshaft have worn so that the engine misfires. I understand from other posts that some believe that the active fuel management (AFM) system has led to that type of failure. So, I am desiring a bigger engine.
I am interested in replacing the 5.3L engine in my 2011 Silverado with either a 6.0L or 6.2L engine. I am interested in knowing if the engine mounts are compatible.  Are all 3 of these size engines from the same casting (block size)? Are the intake manifolds compatible? Is the belt assembly compatible?
If you are familiar with any of these aspects I would appreciate your input. I am hoping to purchase an engine that I can take the belt assembly and the intake manifold from the 5.3L to either the 6.0 or 6.2L engine. And, of course, use the same engine mounts.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
