99 jimmy runs rough with ac on
99 Jimmy with 55000kms. When driving on highway with ac on it runs like crap.
There is an initial surge when I turn on the ac (which I think is normal) but then it just continues surging constantly.
Just out of curiousity do you have a 4.3 or a 2.5. I know that the drag of the compressor can slow your motor down a little but it shouldn't be noticable. Make sure your compressor is full of lube and makesure it's not locking up.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
