Bumper pods
Project for the day, easy once I got past the fact that I had to cut holes in the bumper. Won’t really be able to tell how much help they are for another month or two when we finally start to get dark at night again. 81aef179b2e748b770e0fece99934dfe.jpg56a5e6313ce3aec15c4fd4414aa9ced8.jpg
Put them on a toggle switch. They will keep the tailgaters away.
Yup, they are on their own switch. Installed them for the long winters in Ak when it’s dark and I need extra light when secure things to trailers and such.
   Nice upgrade, and fine craftsmanship.
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 857 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
