Grinding noise when accelerating past 60 mph
Hello, I have a 2002 gmc 2500 HD 6.6l 4wd. Recently I have been driving on the highway and at about 70 mph I’ll hear this grinding noise about where my transmission and drive shaft is. When I let off the gas it clunks then if I  immediately go back of the gas it will make a loud grinding noise again. If I’m driving at a lower speed it doesn’t do this. It’s starting to get louder and sound worst and now it’s doing it at about 60 mph, so I was wondering if anyone knows what it could be. I’m getting several different answers, anywhere from u joints to transfer case to even a bad Emergancy break.
I would drop the T-case fluid and look for metal or metallic glitter in the fluid. Then I would grab the drive shaft and shake it vigorously to check for play. Then I would drop the rear diff fluid and inspect.
I’m with a ujoint. In time it will get a bit worse at lower speeds.
Outside chance the pumpkin [emoji316] because you heard a clunk and GM is known to have some clunks in the rear end.
Time for u-joint replacement. Might as well replace others on that shaft while you have it out
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 396 Guests (See full list)
