Yet Another Head Thread
OK, so I just picked up a 5.3 block that has been bored to 3.898 as the start of my 247/5.7 build for my Suburban
Seller is throwing in a set of 862 heads.
I also came across a set of 241 heads.
I know everyone talks about the vaunted 243/799 heads, so what are your thoughts on using one of the other two sets?
I believe the 241's use the same 2" intake valves as the 243's.
The 241's combustion chambers are +/- 2cc larger while the intake runners and exhaust ports are slightly shorter/smaller.
All of this "matters" the big time LSx guys building them for F-bodies and Vettes looking for HUGE how numbers and top end.
I question how much they would make a difference that would make in my Suburban build.
Keep in mind, the Burb is a DD and part time tow rig.
Sent from my moto g(6) using Tapatalk
I'll be running stock crank, stock rods, flat top pistons, Comp trunion upgrade, Blue LS6 springs, stock rockers, new 7.4" pushrods, new Delphi lifters, a cam in the 208-214/208-214, 108-114 LSA range, shorty headers, Flex Fuel injectors, and likely a TBSS intake.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
