1996 GMC Sierra,New fuel pump, new fuel relay, also new ignition switch, still no signal to the system, is there any fusible links in the system
Under the relay between the the relay and the fuse , I had to pull the fuse box loose and move it over and file through the wires
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
