Rhythmic vibrations in 6th gear when applying load
I am having rhythmic vibrations in 6th gear when applying load to my AWD 2008 Sierra Denali.  The noticeable vibration starts around 60 mph and if I let off gas or place truck manually into 5th gear the vibration disappears.  I do not notice it at lower speeds or in any gear besides 6th.  Transmission fluid has been exchanged every 50K and was done about 25K ago.  My front axles are fairly new at 1 year old and front u-joint changed few months ago.  I can’t hear any sound but notice vibration through floor.  I do not notice any slack in rear u-joint at all.  At this point, I am either thinking transmission or exhaust.   Any diagnostic ideas would be welcomed.
    • For a limited time, Preferred Customers and online/catalog customers get a free magnetic level with their order of $100 or more when they use code LEVEL726 at checkout. Offer ends July 28, 2026.     Save up to 25% off retail as a Preferred Customer.  Sign up here.  https://www.amsoil.com/p/preferred-customer-registration-preg/?zo=521390   As always you can order here.  https://syntheticadvantage.com
    • Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.   "Dirt cheap" (<$100/each) Starfire Solarus (AS or AT) Rocky Mountain HT2  Mohave HT Westlake SU318 H/T Laufenn G FIT Entry Level AS (yes, Entry Level is the name of the brand!)   "Somewhat cheap" (<$150/each but >$100) Kumho Solus TA51a Ironman (Les Schwab) Cooper Discoverer RT AT Hankook Kinergy ST (H735) Milestar Patagonia H/T Toyo Extensa AS II   The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.   Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.   If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.   In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
    • Most vehicles have engine covers. The cooling fan’s are below the cover. That probably doesn’t help. I cleaned collector car engines. The rest not so much since the last one protested by missing for a few days drying out.
    • Point of clarification on this graph. It is the life of the FLUID not the Transmission being graphed. Compare to his comments below the graph. Get it to the top of the graph and you can kill one in an afternoon.
