Airbag light continuously flashes
2009 silverado. airbag light continuously flashes with no pauses. no codes when hooked up to my scanner which has the capability to read and clear SRS codes. any idea what this could mean?
Probably the airbag sensors in the front behind your bumper. My 08 did the same thing. The sensors are cheap, takes a 10mm wrench. (Use a wratchet wrench) you will have to guess which one it is though. My bad one had a small bulge in it and I got lucky
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
