Starter
Thadd
I just changed my starter on my truck and broke the piece that locks on to the starter. I have no clue what it is called and I need to know if I can get a new one. It's part of the wire that goes from the ignition to the starter. 685f5033c9b73ad2eec38a841f9b6bc5.jpg
Sent from my Pixel XL using Tapatalk
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
