Water damaged headliner?
malamuteman
I have a 2017 Silverado that I bought new in February 2017. After it rained all weekend I went to my truck and noticed it felt humid inside the truck. After looking around I noticed the headliner has water damage from piler to piler. I took it to dealership today which they told me it was the drain channels on the roof. I asked why and was told they got clogged. Has anyone else had this issue? I’ve had a lot of vehicles and never had this issue. My truck is kept clean but does stay outside. However I bought a truck it needs to hold up to the simple stuff like being outside. The dealer is going to warranty it but I’m not keeping it if this a normal Chevy issue that I will end up having cover when the warranty runs out.
This is your third brake light leaking just as the shark fin leaks constantly as well. Keep your eye on that shark fin at your front seat. The dealer blames the sunroof drain channels and all that bullshit, apparently it is that GM doesn't know how to get a goddamn gasket set properly for anything that goes to the cab roof. I've been dealing with this since 2015 when I had 200 miles on my truck. Mine is specifically the shark fin that becomes a problem. Sometimes when it rains it leaks and then sometimes it doesn't go to the car wash it leaks and sometimes it doesn't. I've documented my situation and told them I was worried about mold, having survived cancer with a stem cell transplant I don't need to be around this type of crap, they will cover it under warranty however I would make a big stink about it and see if they can get it fixed right away. When I'm done with this truck I will not be going with GM products anymore which is a shame because it is the little things that they screw up it's not really the big things. Also, be careful when they do a test for water infiltration, my dealer was so stupid that they took a garden hose and they rub it all up and down the side of the truck causing 3 days worth of paint repair.
I do have to say with all the complaints and being back five times or so that the leaking is much less than it has ever been but I feel it will be a constant battle. Therefore I am done with GM.
Good luck with the third brake light leaking, I would have them remove and replace the headliner in case mold develops up inside and if they refuse to do that raise holy hell with the service manager. Mold will not only hurt your health and a very short period of time it will also diminish the quality of your vehicle and your potential resale value.
Would you buy a flood vehicle?
  • 1 year later...
I'm having this same issue.  I bought a 2016 GMC Sierra from the dealership ~$50k, 2-3 months later called them and told them that I have fog and even frost on the INSIDE of my windows (mainly the windshield). Took it to the dealership later and they couldn't find a problem, so I kept driving it.  They looked at the rear sliding glass and the sunroof and didn't see an issue.  I complained about it 4 times over the first 2 years and they couldn't find an issue!  It only fogs up in the Winter here in Alabama, so the Summertime, I was only noticing humidity.  It was under warranty the first several times I've complained and they "visually inspected it". Long story short, just this weekend, I was removing the jack and lug wrench when I felt the back carpet around them was soaking wet in my crew cab and I see round splotches of fuzzy green and black mold between the rear seats!  I started looking at it to find out what was wrong.  Removed the 3rd brake light and poured a full cup of water and pollen out of it! There was mold all under the carpet and even between the leather seats in the back!  Took it to GM dealership, they had to pull everything out, clean it, dry it and apply mildew inhibitor.  They can't fix the stained headliner without replacing it. That requires the windshield to be removed and cost over $1,100 just for the part.  I've been complaining for years about this to GM and it is documented, but now my truck is out of warranty officially, so I'm out of pocket to try to fix!  They offered 20% payment today, and told me that this was a known issue!! Long story short, GM is a bunch of unethical, greedy money making moguls and I'll NEVER own another product made by them again!!!!!!!  Shame on those greed filled con artists for taking advantage of women owners and mistreating loyal customers!!  #NEVERagain
Is GM themselves offering the 20%, or is it the dealership offering it  trying to hide what they should have done long ago?
Pretty sure that the windshield does not need to be removed to get the headliner out.
Do you have a case number with GM?
Remember GM just builds the trucks, the dealerships, who are independently owned, are the ones who maintain them. GM can help you with this if you choose to pursue it.
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,381 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
