To Jump Start Or NOT? I'll Replace Batteries.
I posted about this in a battery jump starter thread.
I have said more than once on here that I replace batteries before they die to avoid having to jump start or get stranded.
I will not use one of those jump packs.
I posted recently that with all the computers in today's vehicles why do this?
Well here's the proof in this thread.
More trouble than a simple battery replacement.
Yes I understand in this instance the jump pack may not have been powerful enough.
I'll replace batteries every 4 years.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
