New to me, used GMC C6500 wrecker CAT 6.6, Allison trans
RichieB9280
Hello Everyone,
My name is Rich, I'm an ASE certified mechanic with over 21 years experience repairing passenger vehicles.  I recently purchased a used GMC C6500 with a Vulcan wrecker body because I'm trying to start a towing business on my land.  She's got a CAT 6.6 turbo diesel motor, and an Allision transmission from what I found searching the VIN and what I saw when I flipped the hood forward and saw a big yellow inline 6 cylinder diesel motor.  This truck while much of it is similar to GM products I've encountered over the years, has a powertrain that I'm not familiar with.  I've watched a few service videos on Youtube to learn general CAT service procedures, but that doesn't help me with the problem I face today.  I bought her knowing the brake lines were in poor condition, and knowing that the motor needed a top end overhaul at the minimum because I got a decent deal on her.  She has a good solid rust free frame, and I took her on an extended road test, 45 minutes all over town and the highway, no problems that day.  I towed two cars then as happens with old equipment I had a failure.  She started struggling to shift into higher gears when enroute to a tow destination, then the transmission began to slip.  I checked her out as soon as I stopped.  I discovered my transmission cooler had ruptured and began to leak, I managed to get her home and I think the trans is okay, probably got a little hot as it was slipping, but she still shifts.
I need two new lines and a new cooler... so I called GM.  GM quoted me around $880 for two lines and a transmission oil cooler!! Considering I just fabricated all new brake lines under this thing over the course of three days in constant snow flurries, making a few more lines even if I have to have them fabricated should be cheaper than those factory prices.
I'm looking for help with aftermarket parts from people who have dealt with or worked with these trucks in the past.  NAPA had no listing, so I'm not going to bother with Autozone and stores like it.  I was thinking of calling 1-800-RADIATOR to see if I can get some sort of universal fit kit.
Has anyone encountered this problem before and repaired with more affordable aftermarket parts?  If so please respond.
Thanks - Rich
Don't have any experience on the 6500, but, unless Allison is different from most everyone else in the transmission game, the pressure in the lines and cooler is not very high.
As for the slipping, depending how many miles you drove with it slipping you may have burnt the clutch discs enough to require a rebuild.
Check wreckers in your area for the lines and cooler.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
