Anyone seen the Rhino rod and reel commercial?
MountaineerTom
It is pretty funny.  It's advertising how tough their rods and reels are.
Shows a guy shaving with a big hunting knife, then breaks to a blank screen and says "Tough".
Then shows him standing in his boat, which is on the trailer, starting the engine.  Then breaks to him kneeling down behind the spinning prop, with shaving cream all over his face,stretching out his neck with his cheek heading towards the prop, then breaks away to the same blank screen as before and says "Rhino Tough".
LMAO, I thought it was pretty funny.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
