Fuel pressure question
I have a 2009 Tahoe flex fuel 5.3.  I have recently changed the fuel pump.  I’m now having trouble with it starting after running and then shutting it off for a short period. I checked fuel pressure at the rail and is within specs.  When I turn off the ignition the pressure gradually increases from mid 50s psi to 75 and then eventually drops slowly after 40 minutes or so.  Is this Normal?  Fuel pressure is built into the pump and I’m thinking my vehicle doesn’t like the new “Carter” pump.  Any insight here?
Do it again with ACDelco Professional.  Fuel pressure should be 43.5 psi running and 50-60 psi when you put the key on.  Key off after charging the rail, fuel pressure should not drop more than 5 psi per minute.  A leaky injector can also bleed off fuel pressure.  Do you have access to a Tech-2 or other bi-directional scan tool to run tests with?
    overspeed
    overspeed
  • Who's Online   5 Members, 0 Anonymous, 1,142 Guests (See full list)
