ABS .........AGAIN
went through the search and found the TSB for it
spent 3 hours this morning tearing down front wheels , down to the sensors
did all that was stated in the tsb
one sensor i need to look at is in the rearwheels
WHERE IS IT
anyone know where the rear abs sensor is located (exactly)
both front wheels had accumulated build up of metal shavings on the outside of the sensors
last night as i pulled in the driveway to stop , i almost hit the van in front of me
pedal went to the floor as it vibrated through the abs activation
wheels were pointed straight ahead , so its not the hub bearings
very frustrating
need to get this one behind me
iv'e got bigger fish to fry
thanks ahaead of time
Todd :smash:
I believe you need to be looking at the right-rear wheel if you're looking for an ABS sensor. Both sides in front are integrated into the wheel hub and right rear is for both rear wheels.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
