Rust Problem?
Looks like passenger side, right above the kick panel.
I wouldn't worry about that little spot until it rots to the point that the light falls off. :smash:
Yeah, Wingnut got the place. I've just never seen rust in an '01 car before.
Well, I figure if it's there, it could be anywhere else...
Thanks.
I would'nt worry about that rust at all, that's unpainted steel, and that's as bad as that will ever get. It's the rust around the Hood Latch where the steel meets that worrys me. If you look under my hood at the loop that fits into the latch, it all rusted where its mounted into the hood.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
