WHEELS sierra to denali change out
i am looking to get a set of denali (c3 ) wheels
the ones most available are the 17" off the denali
i know this will require new 17" tires but i want to stay
the same overall size as i have on the truck now
has anyone done this or know which tire size i will
need to put on these new 17"s wheels
any help mucho gracious :thumbs::):D
Find out what tires are on a Sierra Denali or C3. I bet they are the same diamter as 265's. A guy at work has a C3 I can check his tires if you like.
:thumbs: Sierra Denali and Yukon Denali both come with the same size tires, P265/70/17. Even if your are going to put them on a regular Sierra, I would stick with this size because it is a common size and there are many tires to choose from. They will also fit fine on your truck. If you try to go to a different size in the 17's you will probably pay more because the sizes are not common. However, if you currently have the 255/70/16's on your truck, the equivalent would be 255/65/17's.
I work tonight and he works in the morning so if I wait a few minutes his truck should be i nthe parking lot when I'm leaving. I'm sure Shaydogg is right though that they are 265/70's.I'll check carsdirectand post what they say.
245/75/16 has the overall size of 30.6
285/60/17 in ovearll height is the same but would be wider. This tire would have to mounted on a min of 7.5 inch rim. ( I belive denali has 7" rim.)
265/65/17 has the right height but still needs a 7.5" rim.
A 245/70/17 has the correct height and is 7" rim approved.
I Personally would throw 265/70/17. It is approved ofr a 7" rim.
This tire wil be 1.2 inches taller than stock and .8 inches wider than stock.
There are a TON of tire available at this size Check these out -- Bridgestone Dueler Revo A/T.
Your speedo wont be very off either. (might just set the speedo straight on.)
    Joegstfsn
    Joegstfsn
  • Who's Online   4 Members, 0 Anonymous, 636 Guests (See full list)
