Traction light
Has anyone have their traction light come on and engine light start flashing and truck stuttering took it to advance and codes were MAP sensor which dealership claim they changed and engine oil sensor so it’s at the dealership for the 3rd time help!!!!
We are going to need more information.
Year/Make/Model of the truck.
What codes are stored?
When the engine light flashes, that means the truck is skipping. Find out which cylinder is skipping and let us know.
The traction light is a system disabled message from the ECM. Nothing to worry about. When we fix the skip, we will fix the traction light.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
