Aux switches
I have a 2018 Silverado custom with the cargo light and traction control switches under the radio, I want to put in the gm part that has both of those plus 4 auxiliary switches. How do I know If i have all of the needed wiring? I have the empty pins in the junction block by the brake pedal.
Sent from my SM-G960U using Tapatalk
Check out this forum post. I think there are a few part numbers sprinkled through it. Hope this helps.
https://www.gm-trucks.com/forums/topic/168371-aux-switch-install/
Sent via my cellular device utilizing a chat forum thingy!
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 193 Guests (See full list)
