Towing mirrors
I’ve Got a 2014 1500 slt that was ordered with dl3 mirrors. Truck is loaded with all options. What tow mirrors can I put on without buying extra harnesses? Is this even possible?
  • 4 weeks later...
You Can physically install the tow mirrors on a truck that did not have them.  You can choose to drill a 4th Hole, as I did when I installed mine, but mine were OEM GM DQS Power Folds..... but lots of folks have not installed the hole and either removed the stud from the mirror and or the mirrors don't come with the 4th stud all together.
The Mirrors will function 'almost' as they would if you had the harness.  The 2 things that are different are the forward facing amber LED's and the Rear facing Cargo LED's
the forward facing amber lights will not come on with the parking lights as they would HOWEVER they will come on when the puddle lamps are on, as they share the same pin on the DL3 mirrors
the rear facing Cargo LEDS will not function at all, as there is no wiring present
    timcpeters
    timcpeters
  • Who's Online   4 Members, 0 Anonymous, 1,186 Guests (See full list)
