Bed Swap
Hello folks! Chevy guy here. Just found this forum as I'm interested in finding out if anyone knows if a late model (00 or newer) short bed will bolt up to a 88-98 frame w/o too many problems. A buddy of mine just acquired a truck with a short bed service body and wants to install a fleet side bed and I was just wondering if anyone here has any experience with this.
TIA,
Pedro
Welcome to the forum :thumbs:
I couldn't tell you if the bed would bolt right up, but....Would you really want to bolt that one there? I don't think it would look very good. The horizontal body lines wouldn't match at all....or the trim for that matter.
Just my .02 :rolleyes:
The reason he's considering it is bc he's strapped for cash and found one in matching color at a very good price. Going rate for one down here is $300ish w/o a tailgate.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
