Electrical issues
Radio clock and climate control display reset sporadically along with complete power failure of truck. Battery cables are clean and tight, all fuses and relays seem good. After complete power failure, in a few minutes truck is back to normal and works fine. Anyone had this issue before?
BCM Ground. Probably ( Its here on 01-07)  on frame, or cab mount of frame facing rearward, DS of truck frame.
I did that one a couple months ago and no luck. I did find 2 on driver side of engine block but they were tight. Took fender well cover out and checked all connections there that I could see.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
