Production numbers of 2500 suburban
Hello! I have been reading and learning a lot but I have a question that I have not found the answer to. In 2000-2006 suburban, how common were the heavier 2500 models. I seems like less than 10% based on the ones I see for sale near me. It seems like finding a 9-passenger 2500 is nearly impossible!
Folks keep them until they plumb wear out.  They are around but you have to look far and wide.
Well I found one! It’s a 2001 but only has 113, 900 miles on it. It’s been lied on its entire life so I get the full maintenance records too. I don’t think I could do much better.
That's great Freddy!  Good luck with it!
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 706 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
