Overhead Console -- Help
I have been trying to drop the overhead console on a Trailbazer LTZ.
I removed the two screws in the sunglass compartment, but the enclosure appears to have a forward attachment point. Does anyone have information on dropping the overhead console?
Yeah...I think there is a hole up front....You can see it through the windshield. Should be the same (size) screw thats in the back.
I havn't taken one off of a Trailblazer, and havn't done one of mine in years...So I may be wrong though.
1. Remove the 2 screws that retain the console to the roof panel.
2. Release the front retaining tabs.
this is what service info says
sorry not much help
