Rough idle
hhhhmmmmm...
remove intake and tb. wipe with clean paper towel then spray and wipe down, set aside and let dry. pull the maf and use maf cleaner to spray that. reinstall and re calibrate tb.
If it is a misfire we have different instructions.
all this is assuming you don't have a code reader or better a scanner?
Mine does this as well. The way GM tunes their engine is that when its warm (above a certain temp), the idle drops as low as 450RPM. I noticed that when my needle went below 500, there was a noticeable surge every few seconds.
I took it into GM, and they said this was normal. I think they are full of crap. Cleaning out my TB helped a lot.
To clarify what 1SLOW1500 said above, you should try cleaning your "tb" (throttle body), and maf ("mass airflow sensor").
The throttle body is a damper that opens and closes in response to pressing the gas pedal. It tends to get filled up with carbon over time. Carbon deposits get sticky when hot. This can cause your damper to stick a little, especially towards the closed position when its warm. If your damper is sticking, this can cause your engine to surge, especially when warm. GM tunes these engine to run at the bare minimum RPM to meet their EPA requirements, so your throttle needs to be clean and operating like a swiss watch for your engine to run smoothly.
Here is a video:
Throttle Body Clean
Word of warning. If you pull the thottle body, do not adjust the damper by hand while cleaning unless you have the means of calibrating it afterwords (a ODB utility tool will do). Otherwise, leave it in the position it is in when you pull it. The video mentions this. The consequence of not following this advice will mean your truck will start idling at ~2500RPM until the computer clues in and runs the diagnostic. It can be a little scary, but it shouldn't hurt anything.
As for the mass airflow sensor, this pretty much works as described. It detects airflow through your intake. This reading is used for a bunch of things, and when its clogged with carbon and other gunk, it doesn't read properly. On these trucks, its usually positioned right near the filter box on the passenger side. I'm at work now and can't find the link to a good video, but I'll try to post one later. Cleaning the MAF is stupid easy. You just have to remember that the MAF sensor is delicate, so be gentle with it.
If your truck isn't throwing a code, it is very likely that a idle surge when warm is one of these two things. Most honest mechanics will clean your TB and MAF for you for the cost of an hours labor, if you aren't comfortable doing it yourself. Its a really good starting point to solve your idle problem.
Good luck.
4 hours ago, 1SLOW1500 said:
hhhhmmmmm...
It's not throwing a code just have a rough idle I know it's the 6.2 and it's not smooth like the 5.3 or 5.7 vortec but it's not the cam it's a stumble rough cut out idle
What is the engine temp and the idle rpm?
Just because there isnt a hard code doesn't mean afr or misfire isnt happening
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
