Braking Problems - Stabiltrac / Traction Control System
2 error messages popped up on same day, back to back:  Service Stabiltrac and Service Traction Control System.  Very shortly after this the brake pedal got hard and the brakes begin to apply on their own [no driver input] to the point where I could no longer drive the vehicle, had to stop.  All of this happened within a 5 min period.  The GMC dealer has had truck for a week, worked with the factory, and finally had the dealer do following:
  • Put truck on lift, start engine
  • step on gas to simulate driving
  • when messages popped up and truck started self-braking, lift up on the brake pedal
  • If this cured the issue, factory said the brake booster must be replaced.  If lifting the pedal had not cured the issue, then the master cylinder had to be replaced.
Dealer replaced the booster, took the truck on a drive, and issue repeated itself.  Back to factory again Monday.  Dealer has not seen this issue before.
Has anyone experienced this??
John
I neglected to mention that this same GMC dealer replaced the mechanical diaphragm under a Special Allowance program for the 2017 Sierra paid for by GMC.  The self-braking symptom started about 1 week after the diaphragm work was completed.
  • STANLEY changed the title to Braking Problems - Stabiltrac / Traction Control System
    Sdid
    Sdid
  • Who's Online   4 Members, 0 Anonymous, 1,408 Guests (See full list)
