Will 4l60e from a 97 blazer work in a 2004 blazer?
     Changed them over and getting shift solenoid code. Have replaced both a and b solenoids but still have to change gears manually, didn't have this problem prior to change.
Should be a good swap. Sounds like a possible communication issue. Had you checked all the connections and verified none of the pins were pushed out on the connectors? PCM should toss a code or possibly is missing power.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,046 Guests (See full list)
